How can I get the Row URL to use it in a python script
I use a python script to generate a QR code per row. Which really works without any problems.
But my QR Codes should be the exact row URL, so I can scan it to find this entry.
Unfortunately I don’t know where I can find a kind of dictionary how to name such easy things, so I’m lost.
The way I can do this is by copying the each url and paste it in a column and the use this column in my python script.
But there should be a faster way than copy-paste 200 url
Thank you for any help
Here is the python script I use:
import os
import time
import qrcode
api_token = context.api_token or “…”
server_url = context.server_url or “https://cloud.seatable.io”
STRING_COLUMN = “link” # text column which is expected to be transferred into qrcode
# but instead I want to directly refer to the url
IMAGE_COLUMN = “QR Code”
TABLE_NAME = “2023_CRM”
OVERWRITE = True # set to True to overwrite existing barcode images
base.auth()
qr = qrcode.QRCode(
version=2,
error_correction=qrcode.constants.ERROR_CORRECT_L,
box_size=40,
border=8
def get_time_stamp():
return str(int(time.time() * 100000))
def main():
for row in base.list_rows(TABLE_NAME):
if not OVERWRITE and row.get(IMAGE_COLUMN):
print(“Skipping row. Image already exists.”)
continue
try:
  row_id = row.get('_id')
  message = row.get(STRING_COLUMN) # what can I write here to use the row url directly without copy-paste it beforehand in this column?
  if not message:
    print("Skipping row. Empty message.")
    continue
  # clear, add data and make an qrcode object
  qr.clear()
  qr.add_data(str(message))
  qr.make()
  img = qr.make_image(fill_color="black", back_color="white")
  save_name = f"{row_id}_{get_time_stamp()}"
  img.save(f"/tmp/{save_name}.png")
  # temporarily saved as an image
  info_dict = base.upload_local_file(f"/tmp/{save_name}.png", name=None, file_type='image', replace=True)
  img_url = info_dict.get('url')
  base.update_row(TABLE_NAME, row_id, {IMAGE_COLUMN: [img_url]})
  # remove the image file which is saved temporarily
  os.remove(f"/tmp/{save_name}.png")
except Exception as exception:
  print("Error occurred during Image generation:", exception)
  continue
if name == “main”:
main()
The row ID is indispensable for working with records in SeaTable.
There are various ways to obtain the row ID of a record:
