the link about webhooks is not available: https://seatable.io/en/docs/handbuch/expertenwissen/webhooks/
I see in API I can make webhooks but I don’t see how I choose the table that triggers it.
Thanks
Thanks
Thanks for pointing out that the link is broken, we’ll check it out.
Here you can find the instructions for setting up a webhook: Anlegen und Löschen eines Webhooks - SeaTable
That’s looks great , but I have a problem -
I want to get data from a form.
The event of adding a row does triggers the webhook, but the “data” collection is empty!
So how can I get the data from the new raw created by the form?
@discobot can you help here?
Please see here: https://forum2.seatable.io/t/data-in-webhook-is-empty-when-form-is-submitted/2660/2?u=rdb
