How to delete synchronized dates in a Google calendar?
Dates in a SeaTable Base can be automatically synchronized with one Google calendar. This synchronization works seamlessly through automations. The available actions for synchronization are ‘create’ and ‘update’. However, there’s a missing feature: ‘delete’. Consequently, it appears that events created in a Google calendar cannot be deleted. For now, n8n can handle this. It would be greatly beneficial if the ‘delete’ action were added to the available options.
Setup: SeaTable Self-hosted, version 6.1.8.
Thanks for reporting the issue. We will try to add the missing feature in a future release.
Do you mean you want an event in Google calendar be deleted when the corresponding row in SeaTable is deleted?
Currently, SeaTable does support actions to be trigger when a row is deleted.
No, I don’t. When a row is updated, it can assign an event a specific status, such as ‘cancelled’. It would be great if the event in a Google calendar could be deleted based on a specific status.
Thanks for the clarification.
The feature will be added in version 7.0.
