Hello,
I have two task lists.
The first one is shared with my coworkers in a table where task are assigned, it works well
The other table is personal, with private info that my buddies don’t see.
I would like to make a private table that merges both task and update their status in their respective tables.
How would you proceed, knowing that I’m selfhosting my seatable ?
best
You would quit having two tables and put them all in one. You add a single select column with two values “public” and “private”. Then you create a view that filters for the public values. This view, you share with your co-workers
Having the same entities in two different tables does not make sense.
You’ll have to update to SeaTable Enterprise though. “View sharing” and “custom sharing permissions” are Enterprise features.
I don’t see an easy way to do the same with SeaTable Developer Edition.
thanks, for confirming
that was also my thinking.
