How to Install a New Seatable on the Same VPS?
Hello,
I have Seatable installed on my server, which I mainly use for personal purposes. Now, I’d like to set up a new Seatable instance on the same server for my business and create accounts for my colleagues. How can I do this?
I considered paying for a new server, but I believe there must be a way to use the one I already have. I’m not very tech-savvy and I’m concerned about potential conflicts with default settings such as roots, ports, etc.
Any advice?
Thanks!
Hey ENVC,
With docker this is absolutely possible, but it will require some modification on the existing docker files like changing the used networks. If you are not familiar with docker, I would recommand to pay the small amount extra and book a separate vps.
