How to Integrate AI? What's Wrong with My Configuration?
Environment: Debian + Docker
Version: seatable-developer 6.0 and seatable-ai:latest, both running on the same host.
My .env file includes seatable-ai.yml , with the model provider set to “other”. I’ve enabled AI and configured the URL as follows:
COMPOSE_FILE='docker-compose.yml,seatable-ai.yml'
COMPOSE_PATH_SEPARATOR=','
# LLM
SEATABLE_AI_LLM_TYPE='other'
SEATABLE_AI_LLM_URL='https://api.XXXXXX.XXX/v1'       # /chat/completions
SEATABLE_AI_LLM_KEY='sk-BXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX3'
SEATABLE_AI_LLM_MODEL='gemini-3-pro-preview'
ENABLE_SEATABLE_AI=true
SEATABLE_AI_SERVER_URL='http://seatable-ai:8888'
I checked the Docker logs for both seatable and seatable-ai containers, and they appear to be running normally:
root@debian:~# docker logs e417b8828390
root          13       1  0 16:54 ?        00:00:00 /bin/bash /scripts/seatable-ai.sh
root          17      13 99 16:54 ?        00:00:01 python3 main.py --pidfile /opt/seatable/pids/seatable-ai.pid
root          25      13  0 16:54 ?        00:00:00 grep seatable-ai
seatable-ai started
This is a idle script (infinite loop) to keep container running.
root@debian:~# docker logs 2426f88cee75
*** Running /etc/my_init.d/01_init.sh...
*** Booting runit daemon...
*** Runit started as PID 26
*** Running /templates/enterpoint.sh...
2025-11-25 17:35:38 Start init
2025-11-25 17:35:46 Nginx ready
2025-11-25 17:35:46 Updating CA certificates...
2025-11-25 17:35:52 Start server
SeaTable started
However, in SeaTable’s automation rules, there are no AI actions available to select.
Could anyone help me figure out what the problem might be? Thank you!
SeaTable Developer Edition does not support AI. Please switch to enterprise edition.
Best regards
Christoph
Hi Christoph,
Got it. Thank you for the clarification.
Best regards
