Sambho
January 6, 2024, 5:53am
1
Team
I have a table view, with grouping based on two columns. For example, the table view looks like in the screenshot 1 grouped by certain columns.
When I check the timeline view, all the tasks of my table are listed one by one in the timeline view, and are not grouped as in the Table view.
Is there a way that I can have the timelines of the tasks grouped in the same manner as in my table view.
Thanks for your help.
Sambho
January 6, 2024, 5:54am
2
I am attaching the timeline view as well for reference.
fsa
January 8, 2024, 8:08am
3
Hey,
have you checked the settings of the Timeline Plugin and selected “OKR View” you created?
It seems like this is still an issue I tried grouping in the base table and then creating Timeline view and it only groups at the first level it doesn’t allow you to show the timeline view with nested groupings
Timeline view only supports one-tier grouping right now. It does not supported nested groupings.
Will that change in Seatable 6.0?
