ctxusr
1
iam running the latest seatable version, but i dont get it realized to implelent a calender O_o
Does anybode have a step by step instruction?
ive tried this first by using
in the second link / manual a cannot use the correct format for example because iam missing the switch …
thanks in advice
rdb
2
Please select that correct table that contains the date/date-time information.
Then also please make sure that your columns are formatted as date columns.
ctxusr
3
how do i do that, its not clear how to set this up
This Template might help you: Template: Team meetings
