Hello.
I currently have a customer who is using the Plus plan. He wants to switch to the free plan.
What happens to the information on the dashboards? The customer currently does not exceed the “Storage used” and “Row used”.
Best regards and thanks for your future reply.
rdb
2
Welcome to the SeaTable forum!
I am not sure what you mean by dashboards. (SeaTable does not use this term.) So my answer may not be as precise as you may hope.
But generally, you can downgrade to Free and continue working with your data as long as the team does not exceed the plan’s limits.
Hi. Sorry for my English. Your answer is correct. Thank you very much for your reply.
Best regards
Note: You can close this query if you wish.
rdb
5
No worries for your English.
I am glad I could answer your question.
