Import CSV: Link to other Record Column
I have a CSV that I am importing and one column in the schema is a link to another table record. I am using the first column value as the value in the CSV but it’s not importing data into that column… it’s not an option in the preview. Is that not supported?
You cannnot directly import links into a “link to other records” column.
You can import a foreign key in a text column and then run the “auto add links” operation. It’d say this is what solves your problem. The only shortcoming: It’s two steps rather than one.
