Import GPS data in a table
Hi,
I’m new about SeaTable and I have a little issue about import GPS data.
I’m importing data from an Excel file, several cols for GPS values both Long, Lat and DMS format, but they’re recognized as MultiSelect type.
How can I do. There is a specific format to use ?
And if i wish to insert data via API (with Make for example). If it’s possible, how ?
thx
Screenshot of the import file….
I agree, importing a geolocation column is awkward.
This is how you can do it:
  • Import the file without doing anything special → you’ll end up with geodata in a multiple select column
  • Add a formula column and add the function {<column_name>} where <column_name> is the name of the column storing the GPS data. → the column shows the values a comma-separated text
  • Add a geolocation column
  • Copy and past the content from the formula column to the new geolocation column
Hope this works for you. We’ll improve the import in the future.
Thx Ralph for your help,
no problem with point 1,2,3 but copy/past to the geolocation column seems to be not possible… i’ll attach the screen shot … no data copied
witch format should be the gps data: DD o DMS ?
Hi @EmaTeo,
Sorry for this late reply, I hope it could help you anyway… Here is a little Python script that might do the job for the last step. Actually, the Geolocation column is expecting an object containing both lat and lng key with DD coordinates value. You will have to modify the TABLE_NAME, TXT_COORDS_COL and GEOLOCATION_COL at the beginning of the script to match your needs (probably only the table name as I used the columns’ names from your screenshot).
import re
TABLE_NAME = 'Table1'
TXT_COORDS_COL = 'GPS'
GEOLOCATION_COL = 'RealGPS'
def dms_to_dd(dms_str: str) -> float:
    dms_str = dms_str.strip().upper()
    direction_match = re.search(r'[NSEW]', dms_str)
    if not direction_match:
        raise ValueError("Missing N, S, E or W direction.")
    direction = direction_match.group()
    dms_str = dms_str.replace(direction, '').strip()
    pattern = r"""
        (?P<degrees>-?\d+(?:\.\d+)?)\s*°?\s*
        (?P<minutes>\d+(?:\.\d+)?)?\s*[\'′]?\s*
        (?P<seconds>\d+(?:\.\d+)?)?\s*["″]?
    match = re.search(pattern, dms_str, re.VERBOSE)
    if not match:
        raise ValueError("Format DMS invalide.")
    degrees = float(match.group('degrees'))
    minutes = float(match.group('minutes')) if match.group('minutes') else 0.0
    seconds = float(match.group('seconds')) if match.group('seconds') else 0.0
    dd = degrees + minutes / 60 + seconds / 3600
    if direction in ('S', 'W'):
        dd = -abs(dd)
    else:
        dd = abs(dd)
    return dd
base = Base(context.api_token,context.server_url)
base.auth()
rows_data = []
for row in rows:
  lat = dms_to_dd(row[TXT_COORDS_COL].split(',')[0])
  lng = dms_to_dd(row[TXT_COORDS_COL].split(',')[1])
  print(str({'lng': lng, 'lat': lat}))
  if lat and lng:
    rows_data.append({
      "row_id" : row['_id'],
      "row" : {
        GEOLOCATION_COL : {'lng': lng, 'lat': lat}
base.batch_update_rows(context.current_table,rows_data)
Bests,
Benjamin
THX Benjamin,
with your tiny Py the problem is fixed … I really appreciate it :folded_hands:
but now i have another issue while display with MAP add-in…very very strange: using a view two gps point are not in the correct position despite the GPS coordinate are exactly calculate !?!? the same point with global view (without any filter) are in the correct position
Emanuele
Hi again @EmaTeo,
One word is probably missing in your last message: are you saying that in a filtered view, some of the points are not in the correct position (but not every points)? If that’s the case, that’s definitely really weird?!
Even if you can’t share your example, can you at least tell us more about your use case: which column (what column type) is the filtered you use applied on, etc.?
Bests,
Benjamin
Hi Benjamin,
thx for your response. Actually with last new creation of a different table with the same coloumns the issue is not present..very weird … that’s ok so for.
bests,
Emanuele
