installation of seatable on 2 servers and 1 db
already installed seatable to 2 servers with one centralized db. but i keep getting errors when i do the configuration on front end server 2. Front end server one works just fine. but connecting server 2 to the dB is becoming an uphill task
I don’t understand what you try to accomplish.
Do you want both servers to use the same databases? (-> SeaTable Server instance 1 and SeaTable Server instance 2 use the same dtable_db, ccnet_db, seafile_db?)
Or have you created a second set of databases? dtable_db2, ccnet_db2, … for instance 2?
In any case, the former does not make sense and latter sounds like a recipe for disaster.
This is what i seek to accomplish
I repeat my questions:
Do you want both servers to use the same databases? (-> SeaTable Server instance 1 and SeaTable Server instance 2 use the same dtable_db, ccnet_db, seafile_db?) this
You want two different application servers to access the same databases? How do you expect conflicts get handled?
Not only is this no supported setup, it is a bad idea.
