Issue displaying linked entry informations in single record page
Hi,
Using Seatable cloud, I have a problem to display informations of linked entities when using a single record page.
As you can see, informations are well displayed in table (image 1), but when I click on the entity, I have only the first column value (image 2 and 3) even if all columns are checked in the display panel (image 4) :slight_smile:
Bahaviour is the same is the linked column is set as “Text” instead of “Table” in the single record page.
Is that the expected behaviour or do I miss something in settings ?
Thanks for you answers.
Cheers,
Fabien
Hi Fabien,
You’re right, one setting is missing on the page level (ensure to deselect your linked records table to find this setting under the list of columns/fields you can add on the page):
output
Bests,
Benjamin
You are right, it’s working :folded_hands:
Thanks so much for your answer.
Fabien
