Length operator?
Does SeaTable have a Length operator?
Example:
select * from MyTable where length(Col1) < 10
This will get all rows where the length of the value in Col1 is less than 10 characters long.
Hi @nbrege,
Looking at the SQL Function Reference, then len() function seems to be what you’re looking for:
select * from MyTable where len(Col1) < 10
Bests,
Benjamin
Thank you! That was the issue. I looked for that in the documentation but couldn’t find it.
