Let Make automation start via Button in Seatable and send Record ID additionally
Hi there
  • I am using SeaTable Cloud,
I am using a custom web hook to start my automation in make.
The web hook will fire off when I hit a button in Seattable.
In airtable you can add certain parameters to the webhook url which will be received within the we hook module in Make. (see screenshot)
Having no code Background: Is there a way I can realise this in seatable, too? If yes, how do I need to modify the web hook url?
Thanks for your help,
Tim
Your button action is “Open URL”, right?
Then I don’t understand your question. The description clearly states, how to get the value of a column and use it in the “Open URL” action.
Yes, correct. But Maybe I am just not getting it: The row ID provided by seatable which is needed to “Get a row” is not directly displayed and is not a value of a column I can provide myself.
Please consult the other forum posts or the manual to learn more about the row ID (e.g. What is the rows-ID?)
