Limitation of file upload size
Hello
I have a size limit around 1MB on my seatable instance for file attached in a table, any idea about the config issue ?
thanks
Edited Details :
  • SeaTable Server edition (SeaTable Server Developer 3.1.0)
  • Compose file :
version: '2.0'
services:
  db:
    image: mariadb:10.5
    environment:
      - MYSQL_ROOT_PASSWORD=*********
      - MYSQL_LOG_CONSOLE=true
    volumes:
      - /opt/seatable/mysql-data:/var/lib/mysql  # Requested, specifies the path to MySQL data persistent store.
    networks:
      - seatable-net
  memcached:
    image: memcached:1.5.6
    entrypoint: memcached -m 256
    networks:
      - seatable-net
  redis:
    image: redis:5.0.7
    networks:
      - seatable-net
  seatable:
    image: seatable/seatable-developer:latest
    container_name: seatable
    ports:
      - "8080:80"
      - "8090:443"  # If https is enabled, cancel the comment.
    volumes:
      - /opt/seatable/seatable-data:/shared  # Requested, specifies the path to Seafile data persistent store.
    environment:
      - DB_HOST=*********
      - DB_ROOT_PASSWD=*********  # Requested, the value should be root's password of MySQL service.
      - SEATABLE_SERVER_LETSENCRYPT=False # Default is False. Whether to use let's encrypt certificate.
      - SEATABLE_SERVER_HOSTNAME=********* # Specifies your host name.
      - TIME_ZONE=Etc/UTC # Optional, default is UTC. Should be uncomment and set to your local time zone.
    depends_on:
      - db
      - memcached
      - redis
    networks:
      - seatable-net
networks:
  seatable-net:
  • Config files
    not sure what is useful here ?
  • Log files
    when I try to upload, these files are updated :
  1. /opt/seatable/seatable-data/nginx-logs/dtable-web.access.log & socket-io.access.log
    no errors listed
  2. /opt/seatable/seatable-data/seatable/logs/dtable-socket.log & dtable-server & dtable-db & dtable-access
    no errors listed
  • Operating system
    Debian 10
Please provide additional info: https://forum2.seatable.io/t/read-before-you-post-in-admin-talk/22
I’ve added details, sorry
What’s the exact error message? Screenshot? Did the error appear after the update to 3.1 or not?
Based on the info available, I’d say nginx is the culprit. Is there a max client body size directive in your nginx.conf? You can also check the fileserver settings in your seafile.conf.
Just to mention it: I just uploaded a 5MB file to SeaTable. There is no general issue.
I’ve got :
a pop-up “Error”
a grey mention “Network error”
Issue appears as soon at we hit the 1MB limit.
Ok, it’s fixed.
A brief chat with my site sysadmin got the answer. Their nginx was set at 1Mb
Thanks for th equick answers
