Link/Lookup States/Provinces and Countries
I’m on a free account on SeaTable Cloud.
I have 4 tables.
Countries with Country Code and Country Name
States-Provinces with State/Province Code and State/Province Name
Locations with a Country_Link field linked to the Countries table and States-Provinces with a State-Province_Link field linked to the Countries table.
A Battery Capacity Data table with a Country_Link to the Countries table and a State-Province_Link to the States-Provinces Table.
Currently Battery Capacity data entry requires selection of both the Country and the State-Province, which would be OK if the State-Province choices were limited to the Country entered. A potential solution is the just select the State-Province and have a column to link/lookup the Country from the Locations table. I’ve poked and prodded. I see some posts here that are similar, but not close enough to find a solution.
Hi @adanks, and welcome to the SeaTable forum!
I’m sorry, I’m a bit confused with your database structure :thinking:, here are few thoughts/questions:
  • I don’t see how you’ll use your locations table: don’t you want the battery capacity data table to be linked directly to this locations table ?
  • I imagine that a state-province is necessarily linked to one single country… Can’t you add a country column in your states-provinces table linking to your countries table ? Doing so, you’ll be able to access directly the linked country once you chose the state-province
Your potential solutions sound good, but as presented, i’m affraid you won’t manage to achieve what you need as it requires either a dynamic setting
which is currently not supported, or an automation rule for your second idea
as there is currently no link between the fields you choose in the battery capacity data table (country and state-province) and the location table you want to use for the lookup.
Bests,
Benjamin
Thanks for your help. I have it working now.
My configuration was not as I described. I intended to Battery Capacity State to Location State, but I couldn’t because apparently SeaTable doesn’t allow linked records from one table (Battery Capacity) to linked records in another table (States in the Location table were linked to the State-Provinces table.)
I ended up abandoning the Countries and State-Provinces tables and changed the Locations table to include Country, State-Province, Country Code, and State-Province Code.
From there I was able to link the State-Province in the Battery Capacity table to the State-Province in the Locations table as State-Province_Link. Then I used a link formula in the Battery Capacity table to link the State-Province_Link and look up the Country from the Locations table.
This works great. I select the State-Province on the form and the Country automatically fills from the link formula.
