Linking Data between columns
Hello, is it possible to add a new column with data from other columns?
Like this:
Column 1: Name
Column 2: Phone
Colum 3: Email
Colum 4 (formatted):
{Name}
{Phone}
{Email}
Thanks in advance.
Easy! Use a formula to concatenate the content from other columns. The formula is as simple as this: {Name}&" “&{Phone}&” "&{Email}
Thank you. Is it also possible to add characters that force a new line? I want the values to be in separate lines.
Formula columns do not support line breaks. Only long text columns do.
Then you need a script that copies values from the source columns in the long text column.
