Linking tables using id after import
Hi folks using cloud sea table. I have imported 2 excel sheets into 2 seatable sheets. Each excel sheet has an id column.
How do i link these columns now that all the data is imported i dont see an option now.
Thank you.
Hi @Elgin, and welcome to the SeaTable forum!
You probably want to use the Auto add links data processing operation, where you’ll be able to choose which column in each table should match to link. If you didn’t created a Link to other records column before running the data processing operation, a new column will be created.
Bests,
Benjamin
Thanks will have a go. Also needing to do sumifs if that’s possible. Thanks
