Long Text Without Formatting Mode (like source view mode or raw text mode)
Hey!
Currently I’m working with longer HTML and other script snippets to do some scraping and ChatGPT stuff.
Now I use the Long Text field because I need to see the whole text snippets visually which is a pain with the (short) text fields because of its size.
Unfortunately, the Long Text field does some formatting, which I do not need in this case. I just want to see end edit the content in raw text or in “source view” like some other web text editor supports.
So really helpful would be:
  • The ability to switch the Long Text column to a “no formatting mode” or
  • a mutiline text field as Column type, without any formatting that can be edited in a popup with a larger editor (like the Long Text)
Is this currently possible and I don’t get it how to do that?
I’m asking because I found another topic that requests the same:
In that topic, someone with a SeaTable Badge states a Feature Request has been added for this request, but I cannot find it in the list of feature requests here:
https://ideas.seatable.io/
So has this feature already be implemented? Or should I add a new feature request?
The topic you’re referring to is from 2021. At this time https://ideas.seatable.io did not exist. Therefore, I would recommend that you create a new issue at ideas.seatable.io.
Ok, done: SeaTable Feature Requests Board
Actually this can be easily solved by putting your text in a code element of Long Text field. (Just add a new line of “```” in the beginning of your text and end of your text)
The long text field using Markdown format. By putting text in a code element, you can preserve the original content.
Hey Daniel,
thanks for the workaround. It is not a perfect solution, since you need to change a cell value only to see its raw content. But it works for now.
In case someone struggles with the backticks like me:
You need to three backticks at the start and the end separated with a space like this:
result = "``` " + the_content + " ```"
base.update_row(context.current_table, context.current_row['_id'], { 'Content': result })
Otherwise the_content gets lost.
