Hey,
I received the following error message from the SeaTable Plugin in Make.com:
What does this mean? Has the API Token expired?
Hey,
After some testing, I found the reason. When you activate the data deduplication plugin, make can not write data into SeaTable.
I can not imagine that the deduplication plugin is the reason for that error. Typically, you get this error message from make.com if you have a single or multiple select column, without any options defined.
The reason is simple: make.com tries to offer you a list of possible select options, but if there are none, this fails.
Therefore: create at least one option for every single or multiple select option. Then you won’t get this error message.
