Make.com Update a Row
In make.com I have connected the module Watch New Rows with my table, but I can not use the Update a Row module.
I see only the Row ID, i can select but not the single columns!
Error: Function ‘v2GenerateInsertRowParameters’ finished with error! Cannot read properties of undefined (reading ‘map’)
Changed the fields from single select too text and then it worked.
What kind of solution does exist when I have other field types in the table and not only text or number?
Hey Joachim,
are you sure, that you use the “official” make.com SeaTable App and also the lastest version? The “update a row” function supports all writable columns.
My assumption is, that you use an old version or the wrong app.
Best regards
Christoph
Hi Christoph,
I use make in the browser with a fresh account in the cloud for my sandbox and the module SeaTable I can find there.
BR, Joachim
Dear Joachim,
single-select is definitely supported:
Can you generate an invitation link to your base and send this to support@seatable.com?
Best regards
Christoph
In my new scenario it worked well and had no issues with single-select. Thanks for the support!
