Maps - Base vs App
I have used the map plugin on a base and it works perfectly, however when i go to add a map page to an app it is not working.
The two are set up identically, just the app version doesnt load any pins
See below screenshots:
Is it possible that the address field column is among the preset hidden columns?
I have tried showing all and nothing happened. Those were actually jsut new fields I added for unrelated issues
We’ll investigate the issue.
The bug will be fixed in version 7.0.
