Mass edit multiple rows
Hi,
I have a table with around 200 records, and I’d like to update one column for many rows at once (but not for all rows in the table).
For example, I have a checkbox column that I need checked for these rows.
Is there a way to do this?
I was thinking about using Automation Rules, but it seems I cannot trigger any rules, since the rows in question are not being edited.
Time-based triggers don’t work either, since they don’t allow changing existing rows.
Thanks!
Can you write JavaScript? I think this can help you to filter and update rows in batch.
I can think of a simple solution:
  1. Create a filter to match the rows you want to modify
  2. Use “drag and fill” or “copy and paste” to quickly change the cells from uncheck to check
Thanks for both of your suggestions!
For now, copy & paste is easiest. Don’t know why I didn’t think of that … sometimes you don’t see the forest for all the trees :wink:
Great! You are welcome! Now I’m marking this topic as solved.
