Modify records with automations for multi-select values
Your Setup:
  • SeaTable Cloud
Is it possible to use a modify record action in automations für multiselect columns, wich not only replace all existing values with a value, but to add to existant values an additional one?
The “Modfiy row” action does not support incremental changes to multiple select columns (or collaborator columns for this matter).
You’d have to use the “Run script” action to achieve your goal.
