Your Setup:
- I’m using the cloud version with n8n 1.109.2 self-hosted
Question:
The n8n community node search method has a limit of 100 records. How can we go beyond this limit with the n8n node ? (I don’t want to use the API / HTTP).
Thanks
Did you see this: Rework of n8n-seatable Integration - #20 by cdb
Hi @hsteph, as far as I know it’s unfortunately not possible… Having a look at the code behind the search method, it actually runs a simple SQL query which as a 100 records limits if no limit is specified (Query SeaTable with SQL). Maybe this limit could be added as a node parameter, what do you think @cdb?
For now, if you don’t want to use API/HTTP, you could eventually:
In short, I don’t see any easy straightforward workaround, but maybe I’m missing something… By the way, the community node had a Make an api call node, which doesn’t seem to exist anymore in the n8n officially integrated ![]()
Bests,
Benjamin
Thanks for the details. I thought this limitation had been dealt with in the official node.
Hi team, can you push engineering to implement a “Return All” feature ?
I see this as a mandatory feature to build real application.
Let me know your decision, thanks !
Stéphane
Currently I am working on Release 6.0 of SeaTable. After that I will work on that issue and increase the limit or add such a “return all” option.
I have published a version 2.1.0 of the community node. It supports return all for these two actions:
In addition, I improved the search row action, providing separated options for different column types.
Please give it a try and report if everything is working as expected.
Thank you,
I should be able to test this next week!
