N8n plugin does not deliver output in case of empty Search Records
Hi,
I use the Seatable node in n8n to distinguish, whether a record with specific content in a specific field is present. After that determination, an existing Seatble record would be updated or newly created.
Unfortunately the node with the “Search a row for a keyword” - in case no record is found - delivers no output. And I didn’t find a way how n8n meaningfully can deal with a node, which returns node data.
In case nothing is found it may be better if the node returns a state message in json, which can be parsed.
(The whole picture might be easier, if the seatable node in n8n would support an upsert operation - like create a record if a key does not exist or update a record in case the key ecists.)
Best regards,
Daniel
Your Setup:
  • SeaTable Cloud, Dedicated or Self-hosted?
  • Selfhosted n8n, version 1.102.4
  • Cloud seatable
  • Screenshots
  • Diagrams with Excalidraw
  • Base structure details using this script.
Error Messages:
If there are any error messages shown in the browser console, please include them for better readability by wrapping them in a code block.
Example of a code block for error messages
Hi @dakoller,
Sorry I just had a very quick look, but maybe you could use the Always Output Data option (in the Settings tab of the node) and then check if _id exists in the output for example…
Bests,
Benjamin
thx @bha, that worked.
The object returned is [{}] (in json) and one can test for the emptyness of the search result with {{ $input.first()._id }}.
