Need mobile apps stat! Android & iOS
Hello SeaTable.
We’re relatively new to bases, and have been learning about SeaTable but have hit some roadblocks that my colleagues don’t like. Example: We’re trying to develop a simple method for our travelling guy to enter a contact, make notes, and set reminders using mobile apps. I was going to set up a base for our travelling user and have him access it via an iOS or Android app, but alas those apps simply do not exist. Your current Android app is very old and when I tried installing it, my device said that it can not be installed on this newest version of Android and will work only on a Chromebook laptop. So for that guy we are going to cobble together a simple task manager, contacts app, and notes app and have him use that as a patch until SeaTable has native mobile apps.
Please escalate your priority on developing these apps. The more I use SeaTable the more I like it, but I find the lack of mobile apps is hindering my migration from other apps over to SeaTable. Native mobile apps are always so much more intuitive.
Thanks,
Rod
Its not a fix, but I can highly recommend Softr for this.
We’ve been using Softr for our front end stuff for a while, and sync everything back into SeaTable for the database
