I just got a notification Ive not seen before:
Any clue as to what this means? Clicking on it within SeaTable does nothing
Root Cause: The error is triggered when you initiates an excessive number of automations within a very short timeframe.
System Action: To prevent the CPU from being exhausted and to maintain overall system performance, SeaTable’s rate-limiting logic automatically blocks the execution of these pending automations.
If you encounter this specific automation limit, you should:
Review Automation Logic: Check for “infinite loops” (e.g., an automation that updates a row, which then triggers the same automation again).
Optimize Triggers: Reduce the frequency of triggers or use “Common Dataset” syncs and scheduled runs instead of “on every change” triggers for high-frequency data.
Batch Processing: If you are using the API or scripts to update data, try to batch updates into single calls rather than triggering individual automation runs for every single row change.
This was my thinking as well, but im unclear as to which automation this is regarding
Is there a way to pinpoint the exact automation/trigger that caused this?
This resource limit is not specific to a rule. You can check the automation usage statistic in the team admin panel to see which base uses a lot of automation.
