Oauth2 Authentification
Hello Seatable-Team,
does SeaTable support Oauth2 Authentification?
Thanks in advance
Cheers
Peter
Hi Peter!
SeaTable does not support OAuth2. But it is on the development plan. If you give the developers a bit more time, you will be rewarded with OAuth2 support. One caveat though: OAuth2 will be a SeaTable Enterprise Edition feature. It will NOT be available in the SeaTable Community Edition.
Hi,
thanks for this quick response!
Cheers
Peter
Hi there,
for clarification - presently https://seatable.io/en/pricing/ states “All plans have the same functions”.
Is OAuth the only exception to this statement or will you be changing the policy in general? I understand that it’s difficult to define your model while the product is under development but do you have a list of other features where you already know will be excluded from the community edition which you can share here?
We continue to enjoy working with SeaTable,
Cheers,
Gustav
At this point, the statement “all plans have the same functions” is true. Please note that the site you refer to is about SeaTable SAAS.
A future SeaTable Enterprise Edition will have some extra features geared towards enterprise deployment, mostly admin-/backend-oriented. The three most noteworthy Enterprise-only features will be
  • SSO/OAuth2
  • Clustering
  • Object storage support (e.g., S3, CEPH)
Thanks ! that was quick and clear.
Gustav
