Suppose we have the following Table:
| ID |
A |
B |
| 1 |
true |
false |
| 2 |
false |
true |
| 3 |
true |
true |
Where ID: 3 is an archived row.
If the filter or corresponding SQL Query is:
“SELECT * FROM Table WHERE A”
both rows 1 and 3 get returned.
However when:
“SELECT * FROM Table WHERE A OR B”
only rows 1 and 2 get returned.
But when using “or()” (Seatable Formula style):
“SELECT * FROM Table WHERE or(A, B)”
rows 1, 2 and 3 get returned.
INFO:
Self-Hosted Enterprise
latest version “3.5.10”
I hope you can reproduce the issue if not please let me know.
Best regards
Thanks for the information. We will check the issue.
If this was a Bug, would you release a Hotfix soon?
And have you been able to reproduce this Issue?
We haven’t checked it yet. We will check the issue in this Friday.
We can reproduce the issue. A fix will be added in version 4.0.
rdb
6
@fjodorsch Now, that SeaTable 4.0 is out, could you confirm that the issue has been solved?
Yes everything now works as excpected after Upgrading to
SeaTable Enterprise 4.0
system
Closed
8
