Hi, in page design plugin I have one text block that could be 1, 2 or 3 lines long.
The following text block should move down/up to keep the same empty line, but there is no option.
Any suggested solutions?
The observed behavior is the designed behavior for text fields (not for tables).
So for Table fields there is no solution to move text from table field2 up or down according to number of lines of text in table field1 which is above table field2?
No.
Seatable would really make a step forward with a plugin for content creation, with fluid blocks that could adapt based on content…
You should try to use small font size!
