Page design question
is it possible in page design to have a clear background on a table. I have a timesheet that I am trying to use in SeaTable that my employer requires.(saved as jpeg and imported as static image.) The font is a little small due to it chopping part of it off if increase the font size. Or can a choose to not have the text vertical centered on the table.
Your Setup:
  • SeaTable Cloud, Dedicated or Self-hosted? Cloud
Absolutely! Simply hide the borders in the section of the same name in the table settings:
how does that make the background clear? I have a jpeg of a timesheet behind it and it have to be able to see the pic of it and just have the numbers show from the table.
I am not sure what you mean by “clear background”. Do you mean that you don’t want any background at all or, in other words, that the background is transparent?
This is not supported. Sorry.
You’ll have to remove the white background using a image editor like GIMP.
Thanks. Appreciate the info.
