Page Design table margin into long text
Your Setup:
  • SeaTable Cloud,
  • Page Design plugin (landscape page)
Hello,
When using a table in a long text there is automatic wrapping although the table could be larger :
Can you change the max possible size of such table ?
Similar topic than :
https://forum.seatable.io/t/seatable-table-in-long-text/1010
https://forum.seatable.io/t/wrap-text-removing-minimum-width-in-page-design-table/1151
Thanks,
Rémi.
Please add a screenshot to generated PDF to illustrate your issue.
see pdf : table is not using maximum width of the page
Please increase the column width in the page designer manually to spread across the entire page width.
The Page Design plugin does not auto-scale the column widths so as to fill the placeholder entirely, neither vertically nor horizontally.
Thanks, however I can not access to single column width since it is a table into a long text.
I try to better show that there seems to be a built in width limit with this small anim :
ezgif-7-1c42d4f326
You can modify the width of every column. Just double click in the table and adjust the column width as you’d do it in Excel.
Bildschirmaufzeichnungvom2024-12-2700-17-35-ezgif.com-video-to-gif-converter (1)
@Remi Did my video above offer a solution to your issue?
