Page Designer - Various Feature Requests
Hi there, I was tinkering with the Page Designer and really like it so far. I have a couple of questions regarding possible features:
  • When using the new Page Number Feature: Is it possible to include the total number of pages? Something like “3 / 6”
  • Is it possible to use regular fields from the table in the header and footer? Would it be possible for instance to define a title or a version column and display that in the footer/header of every page?
  • If the content of a rich text field exceeds its defined area would it be possible to create multiple pages like it is already happening for tables (instead of cropping the content)?
Best Regards
Christoph
Welcome to the SeaTable Forum!
I like your feature suggestions.
Currently not supported. I will put it on the feature list.
First part: Currently not supported.
Second part: This is something you can do by simply renaming the template so as to represent the title and/or version. Then use the dynamic element “template name” in the template.
Currently not supported and not easy to implement, especially when you expect following elements to be pushed down.
