PDF-Layout for invoices
Hi!
I am trying to understand the template “Accounts Receivable” (Debitorenbuchhaltung). When I have multiple products, the invoice does not work (layout). When I insert a table, I cannot adjust the width of the columns. In general, I do not like this layout. Ninox has solved this much better. What can I do? Otherwise I like Seatable very much. But I can’t switch until I can write invoices well.
Many thanks!
Translated with DeepL Translate: The world's most accurate translator (free version)
Hello TaBi,
thank you for your entry. I could not find the problem with the width setting of the columns after testing several times. Regarding your first point about integrating several products into one invoice, there are unfortunately current restrictions. We are aware of these and will try to fix them as soon as possible. We are always working on optimising our solution as best as possible.
Best regards,
Philipp
