I am currently using webforms on Seatable to fill out various forms, but I’ve encountered an issue where previous data still appears when I attempt to fill out a new form. This happens on both mobile and PC, even though the autofill feature has been disabled on my devices.
Hi @Yestoplease, and welcome to the SeaTable forum !
You said you deactivated the autofill feature on your devices, but did you in the devices’ browsers or only in the OS settings ? I read indeed that Firefox for example autofills the forms (see here, ou ici en français comme je vois “kilométrage” sur la capture d’écran). I guess every modern browser behaves the same way, but maybe you don’t want to disable this autofill feature for every form you’ll have to fill in…
Anyway, there’s actually a special autocomplete tag for this purpose in HTML, but I don’t think this as been implemented yet in SeaTable, neither in the form’s nor in the fields’ settings (or at least I didn’t find it). You can eventually add a feature request for this on https://ideas.seatable.io
Hey, there is also a bug with webforms on mobile version. The “autosuggest”-popup from previous entries lays over the input-field. You are able to type, but the content is hidden behind the popup. It would be nice to have an option to disable the “autosuggest” completely in webforms (it does not occur in universal app forms - just webforms). I tried everything in different browsers. There is no browser-setting for disable this “autosuggest”. It seems to be implemented into the seatable code.
