Hi, I’m having problems when a do a request to the endpoint, it give me 500 status error, I have put the base token in the header
If you use a self-hosted version, you can check the logs at the server side.
Hi, judging from your screenshot, you might have manually built this API request in your Postman. We recommend importing all the API calls into Postman by clicking on “Run in Postman” on api.seatable.io on the top right corner. This is to avoid any kind of mistake.
If you have already done this: What “base token” are you using here? Does it start with “ey” and is quite long?
I just tested SQL query via API on cloud.seatable.io and it works.
Spotted something different in your query than mine:
where your indent seems irregular, what I use as indent is like this:
maybe change the indent and try again?
Has the problem been solved?
