Report design - different problems
Your Setup:
  • SeaTable Cloud
  • Report design
Hello, I am experiencing issues with the Report Design plugin. It glitches frequently, makes it difficult to properly adjust the layout, and often fails to include data. Additionally, is it possible to display page breaks for longer documents? When exporting to PDF, the pages often appear cut off.
I do not use Page Design because the text length varies across columns, which causes the content to overlap due to the way it is positioned.
Could you please address these issues? Also, are there any plans to release a tutorial for Report Design soon? (I haven’t been able to find one.)
Thx
@angeled5 Hello, Thank you for resporting issues with the Report Design plugin. We are going to update the report design plugin quite a lot in the coming version 7.1. Please give it a try when it is ready and see if your problems are fixed.
