Hello,
I would like to change the print limit which is currently set to 1000 lines.
Is it possible to modify this limit?
I am currently using Seatable 4.3 enterprise version.
Kind regards.
Hello,
Kind regards.
Hi,
This limit cannot be removed in the cloud area and serves to protect you from accidentally printing X pages if there are many entries.
You can also print more than 1000 entries using the page design plugin and the view element “all records in views”, this option may help you.
Oh great thanks I hadn’t thought of the plugin ![]()
