Running Total of number in rows
I would like to create a running total in a table.
There is a column called “Duration in minutes.” In a formula, all values from the rows above should be added.
As a selection criterion, the column “Order number” can be used: all values in the “Duration in minutes” column should be summed from the rows where the order number is lower than the order number in the current row.
Your Setup:
  • SeaTable Cloud, Dedicated or Self-hosted?
  • SeaTable Version (only necessary for self-hosted):
    You can find your SeaTable Server version at https://your-server-url/server-info
  • Your formula (wrapped as code block)
  • Screenshots
  • Diagrams with Excalidraw
  • Base structure details using this script.
Error Messages:
If there are any error messages shown in the browser console, please include them for better readability by wrapping them in a code block.
Example of a code block for error messages
Try a second table containing the orders only and sum them there
You can use the data processing operation “Calculate sum”
