SeaTable 1.8 out now!
SeaTable 1.8, which we have deployed on SeaTable Cloud today, is a hit! It is filled to the brim with new features and improvements!
This are the highlights:
  • Customizable row height : How do you want your rows to look? Normal height, double height or even bigger? It’s now up to you!
  • Column type Button : Use the button column to automate data creation and manipulation. We’ll consistently expand the actions that can be executed by the click of a button.
  • Data collection form : A tabular view of a table that only shows the rows that the current user has created, they are the tool of choice for bulk updates involving a large number of people
  • External links for views : External links for views allow much finer-grained data sharing with external partners than the existing external links for bases.
  • Sending mails : Save SMTP credentials in your bases - encrypted of course - and utilize them in your JS and Python scripts to send emails.
  • SAML support : SeaTable Server now supports SAML, the popular SSO protocol, which is supported by all the large identity management systems.
You wan to know more about SeaTable? Have a look at the Release Note for more information about these and more highlights of SeaTable 1.8. For a complete list of all major and minor changes in the new version, visit the Changelog.
In a few days, we’ll also update the docker image on Docker Hub. Check back soon!
Congratulations!
At least the external links for views and the row height have been long desired on this forum. Now they are really here.
I can only add my congratulations too, a great step :blush:
good job for the team.
Is there somewhere a list of all requested features and there potential implantation ?
Unfortunately, there is no such list.
The development is very dynamic and such a list would be subject to change.
I can’t wait to update my docker install !!
Hi - I upgraded my docker, but I think the MySQL database wasn’t migrated correctly. Can you help, please? log is here MySQL not migrated to 1.8.0? · Issue #130 · seatable/seatable · GitHub
Did you run the migration script as described in the manual? In your GitHub post, you don’t mention that.
Thanks - I didn’t; I wasn’t at all aware of this. (Coming from services like wordpress and nextcloud, I assumed the DB is migrated automatically.) I’ve added this to my github issue and closed it.
Glad to hear that your problem was solved!
Same here, i had to do the database update manually, Might be interesting to have it automated on seafile.sh restart script
