SeaTable 4.0 is now available! We have updated SeaTable Cloud this morning at 6 am CET. Selfhosters find the Docker image of the the major release in the well-known repository on Docker Hub.
Version 4.0 has many highlights. Here are the highlights of the highlights:
New column type Digital Signature: Integrate digital signatures in your workflows for greater accountability
Built-in file manager: Manage your files more comfortably directly from within the base
Customer folders: Store files for recurring use (i.e., in scripts) directly in your base, independent from any rows
Easier, more powerful integration with Seafile: Integrate existing Seafile libraries with ease and use files seamlessly in your base
Improved universal app builder: Benefit from a lot of improvements in terms of usability and functionality; say hello to the new ‘query’ page type.
You find the complete Release Notes with more details in the SeaTable blog. All changes are available – as always – in the Changelog.
And there is one more change: Since SeaTable v1.0, the price for SeaTable Server Enterprise Edition licenses has not changed. Yet, the recent tectonic shifts in our cost basis require a response. This is why we will adjust the license price. For new customers, the new license prices will apply from August 1, 2023. Current SeaTable Server customers will still receive license renewals at the old prices until December 31, 2023. You find more info here. (The prices for SeaTable Cloud and SeaTable Dedicated do not change.)
The upgrade to the latest version for my docker installation worked perfectly. Trying out all the new features.
Thank you very much and have a great day!
Thanks for this Release. I noticed that none of my seafile attachments can be opened using seatable. It was working before the update. Did I miss something?
It’s working on my installation. Maybe you could provide some more information like, if you are using the SeaTable cloud? And if not and you are self-hosting, did you take a look into the log files?
Yes, exactly.
This happens in all bases that have a seafile library connected. Also this is what my browser says: [Error] Unhandled Promise Rejection: AxiosError: Request failed with status code 400
Thanks for the new feature “add a row” in cells of link columns. There is just a detail which make it unusable for now : when you press “tab” to edit next field, it closes the dialog…
