I have configured AI per SeaTable AI Intergration but cannot select the assistant
I have configured per SeaTable AI - SeaTable Admin Manual
Everything starts OK, but when inside an app, I cannot select the agent.
Suggestions are welcome
Can you post your configuration here? (Remove API keys)
Why app? What “agent” are you referring to? Please elaborate?
Have you read this article which we have linked in all forum posts on the topic?
Sure…go to Apps, and create a new one.
You have several choices, the last of which is “AI” which you can select. This creates a new AI page.
In edit mode, you select the gear wheel to configure the page as you do with all other Apps pages.
Under assistant, you have the option to select an assistant via a drop down, but when you do so, there are no choices.
My assumption is that, given that AI is available for automations, it would be here too.
Note, I have configured SeaTable for AI and with automations it is working satisfactorily.,
Perhaps, this feature just has not been implemented yet.
This page type will not be available in the stable release of SeaTable 6.0 due on Tuesday.
