SeaTable & make Webhook
How do I connect SeaTable to a webhook?
If I change the status in my table to “Approved”, for example, I would like to start a scenario in make.
In SeaTable I have created the webhook and entered the URL.
But when I change something in SeaTable, nothing arrives!
Am I using the wrong webhook?
In Airtable you can select the individual tables, triggers and more. Here there is only one webhook for everything, if I understand correctly.
Webhook integration with make.com
Webhook Integration with Make.com is just working fine.
  • Create a webhook in make.com
  • copy the webhook url to clipboard
  • create new webhook in SeaTable
  • paste the webhook URL to SeaTable
  • change some data in your base
make-webhook
why you should not use a webhook
Nethertheless, I would not recommend to use a webhook. It is much easier to use “list rows” module or the search module instead of a webhook.
Webhooks are from my point of view only necessary if you require an immediate reaction in make.com instead of waiting for the scheduler to trigger…
Look here for more details: Hilfe.
