Sending email configuration failed
Hi SeaTable Team,
I am trying to enable email sending flowing https://manual.seatable.io/config/sending_email/.
When I reset the password of an user, I receive the error Successfully reset password to [...], but failed to send email to [...].com, please check your email configuration..
My email settings in dtable_web_settings.py:
email_data
The logs:
Do you have any ideas where I went wrong? I would very much appreciate your help.
Hi, I don’t see the line SERVER_EMAIL in your settings:
Maybe this is the cause?
Thank you @Karlheinz for the quick response. I have checked it, I have actually the last line. Sorry that the screenshot didn’t show complete information.new_screenshot
OK! I’m pretty sure the problem lies in Gmail.
So, you are sure, too, that your google mail login doesn’t require a 2-factor-authentication? If yes, then you’ll need a device password instead of your login password.
If that’s not the case - have you enabled “Less secure apps” in your Gmail settings? See the following article:
It works, when I enable “Less secure apps” for my Gmail! Thank you very much for the advice :slight_smile:
Do you think that it would be no problem when we use the business outlook email? My Gmail was just a test.
You are welcome, glad to have helped!
And yes, I’m sure it’ll work with your other email accounts too.
I’m glad to hear that. Thank you!
