Setting a default value for a Long Text field
Hi folks – first-time user here, and very much enjoying the discovery process. But… while Long Text fields apparently allow you to create a “default value” (an option I thought was very exciting, given the rich-text content), in practice the default value does not appear when you enter a new record – you get a blank page instead.
This is a real shame – I had set up a fairly sophisticated input “form” which bypassed the need to create a whole bunch of separate fields (all highly individual to each record, so no point creating separate tables), but find I cannot use it. Any thoughts on this?
Glad to hear that you enjoy the discovery!
As for default values for long text columns, they work just fine:
Bildschirmaufzeichnungvom2026-05-2801-51-19-ezgif.com-video-to-gif-converter
Hot dang! You’re right – although I tested the “failure” multiple times with an existing record, I failed to create a new record to test it after having created the default value. And sure enough, as soon as I create a new record, the default value shows up!
Still, I would just like to point out that the default value doesn’t appear when you’re editing an existing record – the field remains resolutely blank. Just sayin’!
But this is a seriously GREAT feature that makes SeaTable even more flexible!
Very pleased to hear that!
This is in fact the designed behavior.
Love to hear the excitement!
As you say, designed behaviour that does make sense. No worries – I’m enthused!
