Setup:
- Self-hosted
- SeaTable Version {“version”:“5.0.0”,“edition”:“developer edition”}
The original xslx file has 12 sheets.
Only 5 sheets are imported.
Error Messages:
No error message.
No error message.
I cannot confirm the issue:
(Tested in SeaTable Cloud)
I assume that you use special characters that prevent the import for all sheets after the first 5 sheets.
You can try two things:
1.) Test the import in SeaTable Cloud.
2.) Change the order of the sheets in your source XLSX file and try the import again.
Both may shed light on the root cause of the issue.
