Show field only when conditions are met issue
Hi, I’m struggling with something that should be simple. if I create a table with multiple columns I can easily use the show field only when conditions are met option in the form builder. However I need to be able to use the conditions against a column that is linked to other records. Any column linked to other records does not show up in the condition selection drop-down.
any advise is appreciated.
thanks
Hey,
Are you using the web form or the form page type in the Universal app?
In the web form, you can only use a condition to define whether the Link to other records column is displayed or not.
In the universal app, you can also set filters in the page settings, please take a look at this.
