The Json import for the single selection does not work.
It always returns:
It always returns:
The import works for me.
Please add more info.
What options are available prior to your import attempt?
None
What options do you try to import?
I am trying to import about 50.000 dates for choosing from a list
Have you tried in a different base?
Yes, I tried this already in different bases
Well, I assume that anywhere in your list of 50.000 entries, you have similar values. This is what SeaTable complains: the imported option already exists.
But I am uncertain if you are allowed to enter 50.000 entries in one single select column. Please use cascading to reduce the number:
Kaskadierung einer Einfachauswahl - SeaTable.
